Cellpro DPM cutting out too soon?
Having a problem with my Cellpro DPM. I'm using a Cellpro 2000mah. 3S 15C. Using a Astro meter it is cutting out at a pack voltage of 10.9V at about 3/4 throttle, if I bypass the DPM to my CC Pheonix 45, no problem, pack voltage at WOT is 10.5 with 21.9A draw, (short burst), Whatt gives[>:]
Regards,
pete
Oops, I left the CC ESC set to auto Lipo, changed it to the lowest setting and is working fine now. I don't understand the reason for having to disable the cutoff in the ESC, but it works
Regards,
pete
RE: Cellpro DPM cutting out too soon?
Pete,
What was likely happening was that it was the ESC cutting off the motor and not the Cellpro DPM. This is the reason we recommend that you disable the ESC cut-off.
I'm glad to fixed it.
