2000MAh pack
AL
i recently got 1 of your packes from locaol hobby shop in hsv Al.
i am running a BL-480 4 turn with a phenix 45
with a 5.5X4.5 it draws 39amps.
If i fly until esc cutts off and land battery is about 117 degrees
2000MAh pack that is 3S2P config
The part that worries me its my Duratrakx ICE charger puts in 2200Mah back in then it shuts off
it has a setting of 110% capicity limit on charging.
i am charging it at 2 amps as recommended.
Should i be worried??
My Feedback: (18)
The instructions I got from my commonsenserc packs says that you should only discharge 80% of the capacity of the pack.
I have also been told that it is tough on your packs to discharge them until the esc cuts it off.
