How low to discharge the NiMH AA batteries???
AZ
I have a radio pack (8 AA cells) Sanyo NiMH 2500mAh that I used for about 1 year. Have always used the Triton to cycle the pack about every 1-1 1/2 months. The Triton was set to discharge the pack to 7.2Vdc (0.9Vdc per cell) and now the pack goes dead in about 7-8 days unused. Have been told that the most I should discharge the pack is at 8.8Vdc (1.1Vdc per cell) but have read last night that the 1.2v NiMH battery SHOULD be discharged to 0.9Vdc...So which is the safe/right voltage to discharge an 8 AA pack?
Right now I'm looking to spend another $50 to get another pack...[&o]
Banned
My Feedback: (9)
RE: How low to discharge the NiMH AA batteries???
I guess it depends on how close you want to get to the edge. There is very little capacity between 1.1 volts and 0.9 volts/cell. The 0.9 volts is used manufacturers for single cells to verify the rated the capacity. In multicell packs taking it to 0.9 volts/cell risks reversal if there is some mismatch in capacity between the cells, therefore 1.1 volts is a safer level.
