Question
Question
I just got a twist 3D .40 size plane, and wanted to get the [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LM0370&P=3]Hydrimax battery[/link]. I was curious about the 750mA limit discharge rate, I will be using it to power these http://www.servocity.com/html/s3001_...l_bearing.html which draw (as I was told) 250mA in full deflection, so say I use all 4 channels at the same time, will I have a problem?
RE: Question
I have no idea why they are limiting the discharge to 750 mA. A general rule of thumb says that NiMh cells can discharge up to 2C or 1650 * 2 = 3.3 A without ill effects. Regardless of what it says you could not have a more typical light load of a receiver and four general purpose servos. If the pack wouldn't handle this for a load not many would get sold.
I wouldn't worry about it for your purposes.
John
John
RE: Question
I forgot to give you the address for Sanyo's web site.
http://www.sanyo.com/batteries/specs.cfm
Input a cell and you can see the charge and discharge graphs for that particular cell. Takes a lot of the guess work out of it.
If you'd like what I consider a better place to buy packs it's NoBs Batteries. They explain what cell is in each pack and its useage.
http://www.hangtimes.com/sportrxpacks.html
John
John
PA
RE: Question
ORIGINAL: R C Jack
Having vented I fill better thanks.....they are derated because they have to be...
I recommend Sanyo HR3U and be safe follow John advice go to Sanyo web and see ....BTW i can not find a spec. on Hydri
Rich
