Chagers?
Chagers?
I have two chargers (see below).
One Pirana 6 - 7 cell 4.0amp charger
One Prolux 4 - 7 cell 1.5amp charger
Does the voltage of the batteries matter??
I have been told I can't use the 4amp charger on the Revo rx pack, but can I use the prolux 1.5A on the rx battery pack?
I suppose the same question holds true for a hump pack battery I have for a Swift 2? (will have to get back to you later with the voltage/mAh rating)
The use of these charges is also highly dependent on when I get my starter box, if I get 2 x 7.2V stick packs, I can continue to use this, if I get a 12V I will be getting the swallow charger which I know charges everything.
So whats the go?
So whats the go?
