AA - vs - AAA NiMh Packs
My Feedback: (10)
I have a 700 Mah, 4-cell(AAA) flight pack; what are the diferences other than the cell size; will the AAA cell pack perform just was well as AA cell pack?
My Feedback: (325)
RE: AA - vs - AAA NiMh Packs
The AA will have higher capacity (up to 2700 mah) and will perform better if the current draw is 1 amp or more. They will have a higher current capability. A weight difference also.
My Feedback: (10)
I would like to use the AAA pack in a RC Skydiver, because of its smaller size and weight; the Skydiver uses 3 servos; 2 regular size to articulate the arms to control the canopy and a micro servo to release the chute; would this AAA pack work for my purpose/use.
My Feedback: (325)
I don't know about that plane, or any planes for that matter. If you can get a hold of the current draw, average flight time for a given capacity then can figure it out. Perhaps someone has that specific plane and knows. I wouldn't thik AAA would be good over just a few amps.
dasintex,
The AAA NiMH pack will work fine in your application, I have two .46 powered fun-fly planes with 5 servos each flying with these packs. They easily handle 3 or 4 ten minute flights. Of course, I would not attempt 6 or 7 15 minute flights with them. In your application with only 3 servos and very short flight times you should be able to go all day with no problems. [8D][8D]........ RJ
