24 volt battery charging
CA
I have two 12 volt batteries wired in series to produce 24 volts on my field box for a large sullivan starter. Where I need help is charging this set-up. I soldered the wiring for good solid connections and the batteries are concealed in the box. It would be very inconvenient to disassemble the batteries for individual charging. I was using my 12 volt wall charger, which did give the batteries a full charge, but after about a dozen charges, it burned up. Is there a charger available that has a 24 volt output? Any help would be greatly appreciated.
