What batteries to buy??
TX
Hello, I just started to build a QQ yak 54 that needs two batteries. One battery is ignition for the gas engine and other is for servos. I don’t know much about batteries except my Futaba standard 600mah works well on my other airplanes with less servos. What would be a couple of good batteries for this plane? What is the best? I will be running two Futaba standard ball bearing and four Futaba High torque servos. I would like to go with 6volt if possible. I am also using a Futaba standard 7 channel receiver. Thanks...........
My Feedback: (50)
RE: What batteries to buy??
for NiMH and Nicad go here for info/batteries
http://www.hangtimes.com/ep.html
for Lithium Ion info/batteries go here
http://www.fromeco.org/
I have used both companies and they are great.
TX
I noticed that the batteries can go up to 7.4 volts. Is this ok for a regular Futaba dual conversion receiver? Can I charge the fromeco on my Futaba charger? thanks for the reply.....
My Feedback: (50)
Fromeco batteries require special charger. You would need to use regulator between pack and rx to bring voltage down to 6 volts. Look at the hangtime website it has some good info reguarding the +'s & -'s of the different battery types. here=
http://www.hangtimes.com/weightcompare.html
