question on and add balancing plugs
Hello
I'm looking to understand better the balancing plug question for lipos
seems like there are two models
A-1 one with -the same size of plug depending of the number of cells
B- 1 one with an increasing size plug with the number of cells.
1/ I want the B model to several lipos
- first is 3S what should the plugin for B type (4 wires plug)
- I have another which is a 4S2P (there fore a 14.8V - 4000 mA) that is only wired with + and - wires
can I balance it in some ways as I'm not sure it's not dangerous to charge it with not balancing.
2/ as I do have only a balanced charger how can I create balanced plugs to +/- plugs which wires go where ?
as an example the 3S plug has in the order : red/orange/brown/black wires ... how to get to red/ black only ? (is it as simple as to only take red/ black.
If you know any detailed page on such subjects thanks to post the URL
Jacques from Paris - France
