Hyperion EOS 7i...first impressions
I did a search and found little info on this charger. What info I could find was positive so I purchased one. After using it I think it's a great charger that gets little recognition. It charges NiMh & NiCd 1-25 cells, Lithium 1s-5s and Lead Acid 1-6. Temp probe included. 10 memory settings plust 2 presets. Easy to use and info is provided on every aspect of the charge, discharge or cycle. Charges up to 7 amps.
I have a 3000mah battery that my two other chargers ( Integy & 969 Super Brain) won't charge. I thought it had a dead cell because both chargers would stop charging almost immediately. The Hyperion charged it and after 3 cycles had it taking over 2800mah. I can't explain why.
Two things I dislike are no backlight and only 3 amps discharge rate. After I've had more time with it I'll post again with more info.
