QUESTION: tx charging time
ON, CANADA
In theory, If I go flying with my Prism 7x and a 600 mah tx battery, and I fly 6 flights of 5 minute duration for a total of 30 minutes actual transmitter usage.
The HITEC manual states : tx usage @9.6V at 200ma.
My question is this: how long should I charge the battery with the wall wart (10.8Vdc at 55ma )before I go to trickle charge without overcharging the tx batteryto bring it back to optimum condition?????
thanks
bootlegr
thanks
bootlegr
FL
1. You should be able to get about two hours of "on" time with your transmitter and a 600 mAh battery before dipping below the 9.6V "safe" threshold.
2. A 55 mA charger is a slow charge rate (C/10), so you can charge indefinitely without damaging your battery. It would take about 15 hours to charge your fully discharged battery at this charge rate. After a brief rest following a full charge, your battery should read about 11.3 - 11.4 V.
- George
P.S. I used to live in Williston, not too far from horse country.
- George
Banned
My Feedback: (9)
Re: QUESTION: tx charging time
thanks
bootlegr
thanks
bootlegr
