discharge limit for 7.4 Li-Ion
My Feedback: (24)
What is the discharge limit for a 7.4 Li-ion battery? In other words, how low can the battery be drained prior to requiring a charge?
What is the rule of thumb for this?
All the Best
clm
All the Best
clm
PA
RE: discharge limit for 7.4 Li-Ion
Yea. the problem is the question of safe battery to hurting the battery. The best is not the question of voltage as much as using up the capacity. For long life aka. 300 cycles. only drain out 70 to 80% so when recharging do not put in more than 75% this is the safe way. Now as you get to this you can check the open cell voltage and loaded voltage and know the truth then recharge at less than 1C..0.8C
Rich
Rich
PA
ORIGINAL: xeliman
in other words dont let t he battery complete empty put a cut off voltage at the esc.i recommend at 4-5volts
Rich
