electronic circuit question
GA
hokay, kinda modding, mostly electronic engineering question...
I need a switch that works like a "press and hold" button, so that a quick taps won't activate it, but only a prolonged "press"... now, the press has to either be able to be activated by a light source (blinky = no activate, but long beam= activate) and it also has to latch, so that when the long beam turns off, it'll stay activated.
if you don't know how to do it, can you point me in the right direction?
basically, what's going on is that I have a Lipoly charger that blinks when it's charging, but shows a steady light when it's fully charged... I have to charge 3 batts, and want to do it while i'm asleep/not paying attention to them (i know it's a bad idea... that's what the steel ammo case is for). they're connected to relays, but i need it to sense that the charger is done, so that when it's a steady light, it'll switch to the next relay.... and so on and so forth.
I have good to decent soldering skills, but the circuit logic isn't really there yet.
thanks
thanks
PA
RE: electronic circuit question
Sooo way toooo much time on your hands ???
First do you know one shots 74121 or any digital... how about old relay ladder logic if this sounds greek then lets stop
Rich
Rich
Take a look here.
http://www.uoguelph.ca/~antoon/gadgets/gadgets.htm
Many more links at the bottom of the page so it should keep you busy for a while.
