how to add balance taps on 3S2P
CA
Hi,
I am making a 3s2p pack and want to know if I can use a single tap at the two nodes and still use the Sonic charger.
I need to order some balancing connectors but I would like to physically make the pack as a 3s2p and not two 3s packs.
Would the charger balancing circuit still work? In effect, would I be trying to balance 3 pairs of cells and just treating each pair as a single cell?
Thanks for any help.
Dan
Dan
RE: how to add balance taps on 3S2P
Hello Dan,
You have the idea here. You can make a 3S2P pack and install the 3S balance connector. The paired parallel cells will act as one Single cell.
Good Luck,
Power . Safety . Life
Brian
[link=http://www.a123racing.com][/link]
Good Luck,
Brian
