Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
Triton-Display Error?
Old 03-18-2003 | 04:08 AM
Default Triton-Display Error?
I set up 3 D/C cycles for my 8 cell 500 mah TX battery. D rate 1.1 amps, C rate 1.5 amps. Nine minute delay before start. After the 3rd cycle ("End"), the Triton display said that the battery charged to 75mah.
I was about to throw the battery pack away, when I decided to try it on my old Accu-Cycle, and lo and behold, it discharged to 518 mah, not the 75 the Triton said it had.
I repeated the whole process again, just to make sure I really saw what I saw.
Apparently, the Triton is charging to the 518 mah, but is displaying only 75 mah. Am I mis-interpreting something, or is my Triton defective?
Old 03-18-2003 | 03:43 PM
Default DisCharge Rate is high
Hey dhable,
Just a thought, what is your (Peak Sensitivity / Threshold) setting? Have you tried to cycle the battery at lower chg and dischg rates? Such as those suggested on the back two pages of the Triton manual. The break-in rates.
See Ya
