Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > Batteries & Chargers
Hecell 1100 mAh nimh 9.6v power pack >
Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
Old 03-23-2003 | 03:46 PM
Default Hecell 1100 mAh nimh 9.6v power pack
Hi
Anyone had a try with this new pack?
I want to use it in my Fundango,
where weight is a cruisal factor.
What RPM to expect with a speed 480bb motor
Gear 1:3.3 and APC 10X7?
Old 03-23-2003 | 05:24 PM
Default HE 1100 Cells
I am much impressed with them. I use an 8 cell pack in my MiniAC 1215/16 geared Swithchback 3D. I have also used the pack in my 54" w/s geared S400 powered Aeronca Champ. They seem at least as good as my nicad 500AR's
I have heard that the KAN 950's should work somewhat better with my brushless outfit, voltage is supposed to stay higher longer.
It remains to be seen how long these cells will retain their punch. I have a lot of small NiMh packs that have much diminished capacity/punch.
Old 03-26-2003 | 12:20 PM
Thanks E-Challenged,
How long the motor is working with those cells?
Old 03-26-2003 | 08:00 PM
HeCells are good to 15-16 amps, after which they deliver unaccetably low voltage.
KAN's are supposed to be good to about 20.
Old 03-31-2003 | 06:11 AM
What about SANYO 1700AUP pack?
Capacity is great,
What about the current?
Old 03-31-2003 | 03:39 PM
Actually, after running the numbers, the HE's should be fine.
Motocalc is saying 5899 static rpm at the prop, drawing 14.5A, and outputing 16 oz of static thrust.
