What is the cheap and best A123 charger & A123 balancer?
PA
Hi
I just built 2 - 5s1p A123 packs from a dewalt battery. What is the cheap and best A123 charger & A123 balancer you can
recommend?What brand , model? Is Astro the best or one of the best?
RE: What is the cheap and best A123 charger & A123 balancer?
i believe IMAX makes one, i'm thinking about using it. if you already have a decent charger, you can look into the Dapter also.
PA
The human error factor is very high for me. Thats why, I am afraid I might not change the battery type and charge the wrong battery with the wrong battery setting...!! Is it true that these multi chemistry chargers warn us when the battery connected does not match the type chosen in the charger settings?
Am I the only risky person here or is there any of you like me?!
Is the cell Pro4 one that also balances - a single chemistry one?
for the LiPo and LiFe battery balance charger, CHARGER POWER can provide, the CHARGERY charger can charge 6S batter pack with up to 8A of charging current , maximal 150W output power, because of A123 cell can be charge at 3C, so the 8A is suit for the cell. for more information, please visit www.chargery.com
IF--you have a Astro Flite 12 or 12Deluxe buy a Dapter and use it tto interface and correctly charge your 5 cell packs - I have done 5 cell packs over n over and if you discharge them to almost dead (3.00v) and recharge them - in a few charges --they end up balanced
I had pigtails on em to balance em and ended up cutting them off and just using the Dapter .
For the newcomer - a 6 or 8 cell charger with full displays is not a bad idea .
There will be more feature laden chargers - in near future - look around -and remember this :
your ability to properly charge depends on the source of charging power - and MOST system stop at 8 amps OR 150 TOTAL watts .
These AIN"T Lipos
These AIN"T Lipos
The FMA Cell Pro 4 is inexpensive enough that I just got another one and wrote A123 in big black marker ink on it and just use it for the A123s. The other one I wrote LIPO on it and just use it for them. I also have different balancing connectors for each chemistry, so there's little chance of a screwup. Plus multiple chargers means I can fly more often.
If you can find a used Astroflight 109 charger you can get a replacement microchip for A123 for $15, but will limit use to A123 only.
Banned
My Feedback: (9)
ORIGINAL: Brad604
GA
OP
Two replys recomended the CellPro 4.
Not sure how one goes about charging a 5S with a 2-4S charger. Cell Pro may be goo but not that good. Guess you could charge 2S then charge the other 3 but the way the CelPro is wired makes that difficult IMO.
The Balance Pro HD does up to 6S 123 and at close to 10A. AF 109 (A123 version ) a bit slower but has a display.
TP 1010C does 6S A123 right at 9A.
Charles
Charles
OH
Who has the CellPro 4 on sale for $60? What else is needed if you get the CellPro 4 to use it for A123 batteries? I want to get some of the newer B&D cells for RX batteries.
GA
FMA Direct
monthly special
http://www.fmadirect.com/new_applica...y_special.html
You will need the CellPro balancing leads / pitail(s) ,one for each battery pack.
The $60 price was a special email price for this week only but I deleted it so do not have the code number.
Found it :
code SP111507
CellPro 4 for $60 Nov. 8-15 only.
Charles
monthly special
Found it :
code SP111507
Charles
MD
Of all the chargers I've used for Lipos and A123 cells the FMA CellPro is the easiest and most accurate. As stated above you need to have proper connectors. I recommend getting the node connectors from the [link=http://FMADIRECT.COM]FMA[/link] site and wiring up any 2, 3, or 4 cell park you use. Ask any CellPro user how they like it. All my friends love them.
My Feedback: (44)
TN
I have been making 2 cell a123 packs from 36 volt dewalt batteries, and purchased a FMA direct cellpro 4s charger for my batteries. i also purchased node connectors from fma for balancing the packs. I am new to a123 chemistry, but seems like great potential. I just love the cellpro charger, and by the way, i just purchased it for $60.00. they have just announced a 10s charger due out in january.
if you already have an strong charger (for NiXX) without Lipo-Mode
i would recommend the Lipodapter
http://www.slkelectronics.com/lipodapter/index.htm
handles up to 10 A123 cells
handles up to 8 LiPo cells
handles up to 8 amps
costs: ~30 Euro
specially with A123 it works great.. i feel no difference to charging with a "regular" charger with A123-mode
costs: ~30 Euro
TN
I am very happy with my Imax B-6. ( https://www.unitedhobbies.com/UNITED...idProduct=5548 ) It's only a 50W charger so it may be a bit slow for those wanting 10C charges but, I'm using my A123's in 2S form as reciever packs with a standard JR connector for the Rx and the balance lead so I only charge my 1100 VPX's at 2.5A for fear the connector will deform. The on board passive balancer seems to work well and the JST-XH connector is the same pin spacing as the JR connector so I just make sure the ground is oriented correctly and plug it in. The balancer gets my packs within .01V
I've done LiFe, LiPo, NiCd and NiMH charges on mine and am happy with it.
Dave
Dave
GA
OP
A CellPro 4 will not charge a 5S pack ,well not for the averge user atleast and a 50 watt charger would only charge at approx. 2.7A so charge times would be close to 50 minutes.
Charles
Charles
PA
ORIGINAL: everydayflyer
OP
Charles
OP
Charles
I agree totally and thats why I got the Astro109 A123 chrger and I love it!!!!!!
GA
A123 M1 support Ver. 2.0 was added to the TP-1010C charger in Dec. 2006 and Ver.2.1A followed about two weeks later to fix a few minor problems.
I was a Beta / field tester for the 1010C( Dec. 2005) and was the one who talked Charlie Wang (Mr. Thunder Power) into adding A123 support.
Charles
Charles
ORIGINAL: Kraeuterbutter
costs: ~30 Euro
costs: ~30 Euro
The thing is, by the time I buy a Dapter and separate balancer to use A123 with my NiMH charger, I am almost up to the price (or with the dual-Dapter, beyond the price) of A123's Hypersonic charger, which has built-in balancing. So it is a struggle to decide what my best/most flexible option is.
GA
I think for 2S and 3S 1P packs Sonic charger is fine. I use 3,4,5 and even 6S packs so the Sonic is not capable enough for me. Also I charge 3S A123 2300 packs in 6 to 10 minutes with a charger that cost me less than $10 to build.
Charles
Charles
Hi there -everydayflier-; I just got two Dewalt 36V packs....I've been flying electrics for a while..but now I want to get into covnerting 40-sizers...what is that device you use that charges in 6 to 10 mins. you mentioned?
