Batteries
FL
Batteries
I have a 10 year old Futaba T6XA that has never been used. I am not confident in the old NiCd batteries so I purchased new ones from tower hobbies. Wanting to improve, I purchased the Sanyo HCAM6363 9.6V 1650mAh NiMH. It has 3 wires coming out of it (red, white, and black with the J connector that would fit in my receiver.
My radio's battery has only 2 wires (black, red). Does anyone know if I can cut and solder the old connector to this battery and if it will work fine with only 2 wires. I don't see why it can't be done, but I need to know what wires to use.
What is the function of the 3 wires on a battery anyway? I thought that they had a + and - side only...
SC
RE: Batteries
They're saving money by using one type of connector for batteries and servos both. The white wire is the signal wire for a servo connection. Simply cut it off.
Dr.1
Dr.1
FL
RE: Batteries
Thanks. I took a better look after I posted and it looks like the black and red wires will plug to the existing plug with the white offset to one side.
