Hobbico Quick Field Charger Mark II
#51
AZ
RE: Hobbico Quick Field Charger Mark II
Here's some info I found.
http://www.reed-electronics.com/ednm...98/01di_05.htm
http://www.angelfire.com/electronic/hayles/charge1.html
#52
Banned
My Feedback: (9)
ORIGINAL: Wayne Miller
With the above information, can you explain why some people have problems with batteries becoming hot during their charging.
I think the answer we are looking for, is how to avoid our battery packs from over heating when charging with this charger?
I found that if I "top off" a pack, I should always discharge a little and it will avoid over heating.
I would appreciate your point of view.
Wayne Miller
Wayne Miller
#53
Banned
My Feedback: (9)
Wayne Miller
Wayne Miller
#54
Thanks Red S.
I understand your explaination of how the heat is generated from charging.
What I don't understand is why the same pack will charge OK many times, but will occaisionally overheat with this charger. It always seems the problem surfaces when trying to "top up" a pack with the MKII.
There have been other threads on this and such things as power source, cell problems, charge rate, etc.
I personally would like to find an explaination that explains what happens to cause the packs to overheat only once in a while. Once I know, I can take the necessary precautions.
Currently, I always drain a battery just a little before charging, about 15 sec, and I have not experienced the heating problem since. This leads me to believe the charger samples voltage and not internal resistance, and is trying to charge to "peak detect", which it can not reach and therefore over charges, but this is just a guess.
I am keeping an open mind while this thread educates me in hopes to find the true answer.
Thanks to everyone who is investigating the problem and hopefully an answer will be found.
Fly4Fun,
Wayne Miller
Fly4Fun,
Wayne Miller
#55
Banned
My Feedback: (9)
Thanks Red S.
Wayne Miller
Thanks Red S.
Wayne Miller
#56
My Feedback: (16)
GA
Red, I never thought about that argument. If the cells dicharge at different rates, the combined effect may overcharge on or more cells but not all.!
#57
Banned
My Feedback: (9)
ORIGINAL: Geistware
#58
My Feedback: (172)
The standard fast charge rate is 3 times the over night rate. So if you have a 1500ma pack that you would
normally charge at 150ma over night, you would charge it at 450ma or about .5 amps. The scale on the charger is amps., and I believe 1.5 amps would be way to much juice to charge a nicad or nimh of this size.
Just a thought.
Rick
Just a thought.
Rick
#59
Red,
Thank you for your concise information on how nicads voltage profile differs from partially discharged to fully charged. Does this hold true for NiMh too?
This information truly explains why the Hobbico MKII sometimes overcharges on fully charged batteries. I have never had a problem with this charger and feel it is a great value and very versatile for the price, but I could never reconcile the horror stories till now.
Thank you once again for sharing your expertise.
John
John
#61
Hi Red S.
Thanks for taking the time to help us understand the battery characteristics and charge problems. It has certainly helped me understand the problem.
Fly4Fun,
Wayne Miller
Fly4Fun,
Wayne Miller
#62
AZ
Thanx for the info Red
My charger randomly fails or intermittently topping off, not topping off.
Im am now using a friends exact same charger with the same packs with absolutely no problems for several months now.
I am sending mine in again to Hobby Services.
I believe there are some units that are out of tolerance or bad components within.
#63
Banned
My Feedback: (9)
ORIGINAL: azvmax
