Triton 2 Problems
AR
Triton 2 Problems
Well its getting that time a year that i start checking my batteries capacity. I pulled my triton 2 out an found that the two buttons don't respond to touch,which is a problem.
Has there been any type of upgrade to this problem or when i send it in will it be fixed with the same parts just to have the same failure agin down the road?
RE: Triton 2 Problems
I had the exact same problem with my Triton (version 1) charger. I thought my charger took a dump. I found out if I pressed down on the buttons hard, it would work. So, I took apart the charger and cleaned the contacts with carb cleaner. Now its as good as new.
