Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
ice problems?
Old 12-25-2007 | 09:05 PM
Default ice problems?
I have 2 7 cell IB1400's... rated for 8.4v and 1400mah.
Set for 7 cell 1400 mah. 2.5 amp charge, 5 amp discharge, 10 mv sensitivity.. using a very powerful power supply.
My (brand new) Ice charger charges the batteries to about 10 volts and only 1050 mah. I have it set to 0.9 v/c max discharge and when it finishes discharging the voltage is around 8. It should be 7.56?
I cycled one of them 6 times and every time the mah went up and the voltage went down.. but slowly... and not a big difference.
What am I doing wrong? This is the first decent charger I've ever had..
Thank you.
Old 12-25-2007 | 10:27 PM
My Feedback: (325)
Default RE: ice problems?
I don't see anything wrong with what you're doing.
Maybe chargeing too fast and cycling too much.
