Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
Super-nova Question
Old 04-18-2003 | 03:02 AM
My Feedback: (16)
Default Super-nova Question
A friend of mine gave me an Apex 7 amp AC to DC power supply to use with my Super Nova charger. After I got it all hooked up and plugged it into the wall I got an overvoltage warning on the Super Nova. I checked the output voltage of the Power supply and it was putting out just over 15 volts. Any ideas on how I can reduce the voltage? I have thought about resistors and even using 12 volt auto lightbulbs to draw some of the volts but I have not tried it yet. Anyone else having this problem? Thanks
Maddogg
Old 04-18-2003 | 01:10 PM
I have no experience with this problem or the PS in question. I can however advise on placing the resistor or bulb in series in the +lead coming from the PS. Placing the resistive item in parallel will only lower the current as voltage remains the same in parallel circuits and is additive in series circuits.
Old 05-13-2003 | 02:30 AM
Epoxy Cup's Avatar
Maddog
I dont know about APEX but I made a power supply from an old computer ($5) and it's running my supernova just fine. Got the how to from Reds battery clinic.
http://www.rcbatteryclinic.com/
