Small 18V pack??
Ok guys, i used to be into r/c cars and i know a lot of people built there own packs. I figured you guys would be the best to ask this question to. I need to build an 18V pack either the same size or smaller than 2 9V batteries. Is this even possible? It is going in an electronic hopper for a paintball gun, and i want something better than regular nine volts. Is there a way to even build a pack that small with that much voltage? Thanks in advance for the help guys.
My Feedback: (325)
If you need it to be smaller than 2 9 volts, then going to a lipo battery would be best bet. For the same size battery you can get a much higher voltage. It should be able to have similar capacity and voltage and be about the size of 1 9 volt battery. I sure don't know where to get the cells though.
Check this site perhaps sorting by size. http://www.progressiverc.com/Research.html Use a 4s or 5s depending upon what actual voltage you need.
Ok, thanks for the help, I really appreciate it. The only problem is i have no idea what all those numbers mean. Is there an faq for that stuff somewhere?? Also i didnt find it showing voltage on that chart. Am i just looking wrong?
My Feedback: (325)
The voltage may not be on there. For lipos a nominal voltage of 3.7 per cell is used , and that will correspond with an empty pack. 4.2 volts per cell is for a full pack. Depending upon how hard the current draw is the operating voltage may be anywhere between 3 and 4 volts per cell. Usually it works out to divide the number of nimh cells by 3 to get the lipo equivellant.
4S column should be 14.8 volts
5S column should be 18.5 volts
You may even want to go with 6S for higher voltage.
Ok, thanks for the help guys. I think i may just make a pack with two nine volts and put a single connector on it. I would then change the dual connector in the loader to a single as well. Thanks, and ill be back, im sure ill have more questions. Thanks Again
Josh
Josh
