Accu-Cycle Pro for DX6I TX
NV
I have the Accu-Cycle Pro, not Elite, and Spektrum DX6I radio. The TX only uses 4 cells and the chargers' TX side is designed for more cells (6, 7, or 8).
Is there any way to use the TX side for cycling/charging the Spektrum TX?
Thanks.
Thanks.
OH
RE: Accu-Cycle Pro for DX6I TX
I have the same problem. So I got a Hangar 9 Sure Cycle cause I have so many 4-5 cell batt. But you cannot cycle or charge the DX6i because of the diode in the circuit. I just took a 4 cell battery holder from my T-Maxx and use it to charge and cycle my Tx batt.
OH
I just modded my Tx so that I can charge it from my charger (Accu-cycle or the Sure-cycle) also this will void the warranty. I opend the case and looked at the charge reciptical and where you put the batterys and thought "why not run a wire from there to there". So I fired up the solder gun and went to work. Now I can plug in my charger to the port and it actually charges now
