THUNDER POWER BALANCING PLUG
i have a 2100 mah TP lipo that i havent been able to use... for example if i were to buy a GP Equinox balancer, where could i buy the balancing plug that would mate with the equinox and thunder power 3 cell lipo... im green to electric
This adapter will work with the Equinox and allow you to charge both ThunderPower and FlightPower batteries. You can get it at your local hobby shop or online.
GPMM3181 Equinox 3S Adapter FlightPower
ORIGINAL: dco1964
ORIGINAL: thedr
I read on the Apogee webiste that balancing was a waste of time and money.
I'll do it for peace of mind, lipos arent cheap
LA
ORIGINAL: thedr
Banned
maybe it has something to do with the packs you're buying
http://www.pfmdistribution.com/
NO GIMMICKS!!!
For years we have sat quietly aside watching the proponents of "pack balancing" spew forth misinformation. The truth is that a properly matched pack will not require balancing. Yes, we're sure this is a shock to many of you who have fallen for the balancing gimmick. Yes, Apogee was the first to put commercial grade plugs on all packs due to customer demand. We've had and seen enough.
Pack balancing is a gimmick perpetuated by companies who make balancers, and by other companies who do not match battery cells within the pack. A properly matched pack will not require balancing, and in fact will mask a failing cell. Balancing is a band aid for companies who lack the proper equipment to do cell matching. All Apogee packs have been cell matched since the day we started.
Due to misinformation, more packs have been damaged during balancing than have been helped. If you insist on balancing a pack (If it makes you feel warm and fuzzy inside, and you sleep better at night, have at it), please, please, only balance fully charged packs.
Why only balance fully charged packs? All properly matched cells are mated together so that the high and low voltages will coincide. There may be mid-point voltage variances. Balancing a partially charged pack can cause the high and low voltages to become unbalanced. Again, please, if you insist on the balancing gimmick, please only balance fully charged packs.
NO GIMMICKS!!!
hi all
a little help here i have a 4cell tp lipo and tp 1010 charger and the balancer what lead do you need to charge this ie the lead from battery balance connector to the data cable to the charger
if you can add a link that would be great
thanks in advance
MAXAMUS...........
thanks in advance
MAXAMUS...........
