Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
trition 2 users..... help
Old 11-01-2008 | 11:54 PM
Default trition 2 users..... help
got my new triton and want to be sure i have it set up corectly for 1100 mha JR transmitter battery.
what are your settings for:
chg current....
discharge current....
discharge cutoff current....
peak sensitvity.......peak delayat start:
temp. scale f....
delay between chg/disch:.....
safety timer.....
thank you
Arden May
i understand that the fully charged battery will be 20 to 30 % less than the total mah rating of the battery is that correct???
Old 11-02-2008 | 11:15 AM
Wayne22's Avatar
Default RE: trition 2 users..... help
Is it a nicad or nimh battery?? Generally charging, at 1C or less seems to prolong battery life. If it is a Nimh battery, JR instructions advise to charge very slowly (like a couple hundred MAH) for the first few cycles...
I normally charge at 3 amp and let the automatic features of the charger take care of everything else.... YMMV...
