Battery Leaked in Transmitter
CA
I have a transmitter where a couple of Energizer Alkaline batteries leaked.
What should I use to neutralize the leakage to prevent further damage?
KW_Counter
KW_Counter
AB, CANADA
RE: Battery Leaked in Transmitter
Mix up a paste of baking soda and water. Smear it over the corrosion and let it sit. Do this a few times then use a light sandpaper to remove the rest of the corrosion.
Banned
My Feedback: (9)
Sorry, what leaks out of an Alkaline cell is caustic, not acid. Therefore you should use a mild acid, like vinegar, to flush the area clean, then rise with alcohol.
