Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
Multi4 and Li Ion
Old 01-06-2009 | 04:42 PM
Mach1's Avatar
Default Multi4 and Li Ion
I need to charge a Turbine ECU pack which is a 2S2P, 5200mah, 7.4v. Li Ion. I have a Cellpro Multi4, 4s, and a Multiplex LN-5014.
With the Multi4 I see no preset for the Li Ion only LiPo.
The LN-5014 has a Li Ion setting but the capacity setting only goes to 5000mah and the voltage setting is 7.2v.
I have no experience with Li Ion types but was under the impression I was to charge it at 1C and the voltage should be set for 7.4v.
Again this is a four cell pack 2x2 in parallel.
thanks
Hunter
Old 01-06-2009 | 05:18 PM
Banned
My Feedback: (9)
Default RE: Multi4 and Li Ion
The LiPo Presets can cover LiIon as well. You can set the parameters any way you want for LiIon.
