Solar Charging
Solar Charging
Well, I have an electric skateboard that takes four 12 volt 5 amp Lead Acid batteries. I was wondering if I could buy some solar panels to put on the sides, front, and back of my skateboard, and have them charge the batteries as I ride the board. Would this be possible?
RE: Solar Charging
ORIGINAL: SacramentoJoe
Maybe you can put some on an umbrella. Charge your batteries while you hang out in the shade.
RE: Solar Charging
Yes, theoretically you could, but the array to provide adequate current and voltage would be so large and unwieldly that you would not be able to use it.
CA
RE: Solar Charging
That doesn't answer my question
RE: Solar Charging
With an average of 250 milli-amps per square foot, you could use a 5 foot diameter umbrella covered with solar cells and get around 5 amps from it. That would probably weigh around 20 pounds.
Then you calculate the amount of drag that mostrosity creates, and I go about 5-10 mph less. >20 mph less on a windy day and I am going against the wind. >500 mph if going with the wind.
RE: Solar Charging
