Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
help!!!!!!!!!!
Old 06-19-2003 | 08:12 PM
dan1220's Avatar
Default help!!!!!!!!!!
Okay, I have a question for all you battery makers. If someone says they are using a 1700 mah reciever pack, does that mean that each cell in the pack is 1700mah?
Old 06-19-2003 | 08:27 PM
Banned
My Feedback: (9)
Default Re: help!!!!!!!!!!
Yes, normally all the cells in a pack are the same capacity and add together to give you voltage in 1.2 volt increments.
A 4 cell 1700 mAh pack will give you 4.8 volts - still 1700 mAh.
What comes into play here is the watt hours, the voltage times the mAh. In this case you would have a 8.16 watt hour pack.
Your transmitter pack of 8 cells if they were all 1700 would have twice the watt hours - 16.3.
