charger issues
charger issues
Hey guys, I have an Airtronics mx sport 2.4 radio. it takes 8 AA cells, I am using NIMH batteries & have always chaged the batteries in the radio with my delta peak charger (just put the correct end on it) however on the mx sport radio it won't allow the charger to start charging. If I use a cheap tricle charger then it will work. Any ideas as to why this is? I like having 1 charger for everything. The delta peak charger does both trickle & fast charge, 4.8 through 9.6 volts.
Thanks, Rich
Thanks, Rich
CA
RE: charger issues
Rich,
I am not familiar with that particular radio.
Many of the radios have a diode in the charging circuit
to prevent damage if the charger is improperly connected.
This diode will prevent the charger from sensing what the batteries are doing.
This could prevent the charger from starting if it can't read the voltage.
I hope this helps.
Good Luck,
KW_Counter
I hope this helps.
Good Luck,
KW_Counter
RE: charger issues
Thank you for the response. This sounds like it could be the case. Oh well I guess I will just have to use a seperate charger for my radio.
Thanks, Rich
Thanks, Rich
