Adding another receiver battery
My Fokker D-VII currently has a 6v, 1400mah NiCd battery, can I add a 6.6v, 2100mah LiFe using a Y harness or will this give me 12.6volts and fry my servos and receiver? As you can see I'm electronically challenged! Thanks for the input.<br type="_moz" />
RE: Adding another receiver battery
Do not mix chemistry with batteries. Either have two 6v NiCd batteries or two 6.6v LiFe batteries. The Y harness will effectively add the CAPACITIES, not the VOLTAGES. You can have batteries of different capacities with no problem.
Stan |
Thanks Stan! I've learned something, happy landings!
John |
What Stan said, just do not try to charge any Nixx batteries in parallel or you will most probably ruin one or both. It is better to hook each battery through it's own switch into a channel on the receiver, just use a spare channel for the second battery.
Is your nicad worn out? Or just need longer flights, or? You don't necessarily have to go to the A123 technology which would require a new kind of charger. It might be simpler just to get a 6.0 volt Nimh (metal hydride) pack of higher capacity. It would be exactly like the one you have except Nimh cells instead of the old nicad type. Your existing charger might already be Nimh capable anyway.
Ernie |
