RCU Forums
-   Batteries & Chargers (https://www.rcuniverse.com/forum/batteries-chargers-84/)
-   -   Hard of Soft case (https://www.rcuniverse.com/forum/batteries-chargers-84/11645709-hard-soft-case.html)
JollyPopper 03-23-2018 04:58 PM
Hard of Soft case
Another question for you folks. Which is better in a truggy? Hard case or soft case LiPo? Or is there any difference?
tntpooof 03-24-2018 08:28 AM
i prefer a hardcase.. can take a few more crashes and bumps than a softy..
stacysouth 03-24-2018 05:58 PM
same as above, i also prefer hard case. there is no other explanation to that.
RustyUs 03-25-2018 04:18 AM
If you are racing, you will more than likely be required to use hard case packs. That should tell you something right there. It's just an added layer of protection.
My first LiPo packs, from 2010, were soft case packs, and are still being used today...still used in harsh off-road environment. But hard cased packs are preferred. Having a very secure battery retention system is a must for any battery.
tntpooof 03-25-2018 05:00 AM
UNtrue like most of your miss information.. get real crushy. now adays most local or club allow you to run any pack soft or hard.. only thing is hv must be charged to 4.20 volts a cell.
collector1231 03-25-2018 07:10 AM
RustyUS is right. Our local indoor track won't let us use soft-case LiPOs, too much of a risk of breaking and causing smoke to fill the place the track is in.
tntpooof 03-25-2018 08:44 AM
when you have guys charging at 10 C .it dont matter what you have soft or hard.. i just raced in pittsburg a clod race they allowed any lipo..same with Michigan . illinois and many others..
RustyUs 03-25-2018 11:32 AM
Bottom line on some "miss" info from me...check with track's rules when you are in doubt. It's that simple.
Bashing rules: anything goes, but keeping a soft case LiPo pack from jumping around in chassis should be the main goal when using them. A small sharp edged pebble/stone is not what you are wanting in between battery tray, and battery. Treat your batteries with respect ... you, and your batteries should have a good life together.
Charging a pack @ a 10C rate...what does that have to do with choosing a soft or hard cased LiPo?
