Changing from needle to LCD
Hi all,
I want to modify my charger, so that it displays the current in digits instead of this inaccurate needle pointer. http://www.gmmodels.co.uk/acatalog/T0246.jpg Protech Delta 10 Intelligent quickcharger. 1-10 Cell (NICD of NIMH), Current: 100 to 4000mAh. Capable of discharging and temprature probing. Plugs into ciggarette lighter. Ive opened it up, and tried making pictures, but my cheapskate wal-mart cam REALLY stinks at macro photography. [:@] So youll have to do with a description. [&:] http://thiscrapis.mine.nu/Meter.jpg Blue = Wires Red = Terminals Orange = Thick Copper Wire. Does someone know how to get this changed to an LCD, so I can set the mAh more accurate? Thanks in Advance, Sven Talboom |
RE: Changing from needle to LCD
You can buy a digital multimeter with a 10 amp current range for cheaper than a discrete meter. Discrete meter are about $60.00 each less the current shunt. Plus you don't have to make a mount for it. Just put the DVM in series with you positive output jack.
http://www.radioshack.com/product.as...%5Fid=22%2D813 22-813 DVM on sale for 20.00. |
Well I could do that, but thats not as "cool". :) Then I could just leave my multimeter hanging from it as I do now.
But that gives such a cable mess when charging in my car. [&:] Id much rather have it built in. |
OK. Simpson 3/64 DIN M135-0-0-11-0 non backlit Allied Electronics # 919-5000 $63.32 This is a 200mV unit. You have to make a current shunt for it to read 4 Amps and you need a separate 5VDC power supply to power it.
Or you could make a calibrated dial using your DVM so that the knob setting is accurate. Lots easier. John |
Heheh, making an accurate knob instead of getting the readout better. [&:] Why didnt I think of that. Thanks!
| All times are GMT -8. The time now is 11:34 PM. |
