RCU Forums
-   Batteries & Chargers (https://www.rcuniverse.com/forum/batteries-chargers-84/)
-   -   Will this setup Work (https://www.rcuniverse.com/forum/batteries-chargers-84/782469-will-setup-work.html)
DrDeath 05-18-2003 06:10 PM
1 Attachment(s)
I am building a flight box similar to those on the Ultimate flight box thread. I need both 12 and 24 volt connections. 12 going to a standard control panel and 24 going to a Dynatron starter. I was wondering if what I am thinking will work. See attachment. Two batteries daisy chained together for the 24 volt connection and then tie the control pannel off of one of the batteries. Seems like it should work. Any help would be greatly apprciated.
Rodney 05-18-2003 07:23 PM
Yes, will work fine.
DrDeath 05-18-2003 07:59 PM
Thanks, after I build this box I will add it to the Ultimate Field box thread.
z11355 05-19-2003 11:21 AM
that will work fine but you might want to
wire up swtich so that you can select
12v or 24v. The switch comes into play
because you can wire it such that you
get 12v @ 2x battery rating (like 2x 7AH -=14AH) OR 24v @ 1x battery rating.
DrDeath 05-19-2003 02:41 PM
z
Can you draw a diagram of what you are saying? Not sure I fully understand what you are describing.
nbcguy 05-19-2003 03:10 PM
Correct me if I'm wrong here, but when you hit the switch on the starter and close the circuit, won't both batteries then be connected in series and temporarily send 24v to the power panel? Just wondering...
theox 05-19-2003 08:44 PM
Wire the battery on the right hand side of your drawing
over to the one on the left, POS to POS and NEG to NEG.
Use a double pole double throw center off switch.
z11355 05-20-2003 01:26 PM
actually, what we did was go in and
cut the traces on the circuit board
so that the 12v starter output jack
was floating and wired directly to the
12/24 switch. The rest of the power
panel was wired to a single 12v pack.
Digitalflyer 05-21-2003 12:41 AM
Careful, it will work but the two batteries will be in different charge states and connecting two batteries like that in serial is not the best idea. It is best to keep serially connected batteries in a matched charge state.
-Amir
