Long term storage of NiCd’s
Is there a way of preparing NiCd receiver packs for long term storage like we would Li-Po’s?
I checked my charger but it doesn’t have a storage option for NiCd’s. The reason I ask is that over winter some of my existing packs have died and I can’t revive them so want to ensure the same doesn’t happen again. |
RE: Long term storage of NiCd’s
It does not matter what state of charge you store Ni-Cd or Ni-Mh. If they cannot be charged at a slow rate (C/10) when you go to put them back into service it is because a short has developed due to separator deterioration, nothing to do with the state of charge when you put them in storage. How old were these packs? You didn't inadvertanly leave them with the switch on in the plane did you? This will kill them over time. Did you happen to measure the individual cell voltages before you tried to charge them? Were any at zero volts?
One of the NASA studies showed that the best way to do long term storage on NiCad was to discharge each individual cell to zero volts using a slow discharge. Then a shorting bar was attached across each cell and then they were stored at a low temperature. I do not recall what the recommended temperature was but I think it was slightly below 30 degrees F. When ready to use them, let them warm up to room temperature and then give them a long slow charge.
ORIGINAL: Rodney One of the NASA studies showed that the best way to do long term storage on NiCad was to discharge each individual cell to zero volts using a slow discharge. Then a shorting bar was attached across each cell and then they were stored at a low temperature. I do not recall what the recommended temperature was but I think it was slightly below 30 degrees F. When ready to use them, let them warm up to room temperature and then give them a long slow charge. |
