seagull edge 540 servos
My Feedback: (76)
ok well i have been runing nitro on my edge 540 now i am going to go to the dle 20cc for a power house i was wondering if i would need to change my servos out to metal gear servos right now i have 3310 on alerions and elevator and then a metal gear 3305 on rudder
Actually Nylon geared servos do BETTER under vibration because they "give" a bit without damage.
Conversely metal gear servos wear more under vibration.
However even a grossly out of balance system is not likely to cause problems with either, as long as the engine is not in direct contact with a servo rod/horn, etc...
If you are talking about say a throttle servo, things may be a bit different, and you may want to make sure that the throttle servo can "give" a bit to deal with vibration.
RCU Forum Manager/Admin
My Feedback: (9)
ORIGINAL: opjose
As to your original question, your original servos will do just fine with the new gas engine in the plane.
Ken
