HOB P51 Candyman
PA
picked up an older HOB P51, has a supre tiger 50 in it, RTF. About 11 years old. Should haul the mail!!! Can't wait to get it in the air!!! Descent shape, with robart landing gear. 48 inch wing span. should rip holes in the sky!!! Or dig a fairly good size hole in the earth
PA
Just picked up the plane. Needs some TLC, but not much. Might turn it into a winter project and paint it more scale. Prop seems to small. might go with a larger prop to slow it down a little. Also noticed the wing mount bolt hole has rounded out not allowing the bolt to tighten. Anyway, I have fixed worse. I figure the engine and the landing gear are worth what I paid for it.
