Sanding Adhesive
IL
I ordered a couple of great planes ez sanders and was wondering, how to use just regular hardware store sandpaper, is there an adhesive I could spray on the back of the paper, or any tips or trick I could use? Thanks
ORIGINAL: SirDank
ORIGINAL: JohnBuckner
Sure just use a spray on contact cement such as 3m 77spray.
I got one and have used it very little. The rounded parts were never the right radius. The 'hard' angles might work OK.
I like Campy's suggestion of glue stick. The sprays are usually pretty messy.
RCU Forum Manager/Admin
My Feedback: (9)
Ditto on the 3M 77 spray adhesive. It is great for attaching "regular" sandpaper the the sander
Also, ditto on the sander that has the 3 shapes on it. I don't even know where mine is any more as it's next to worthless IMHO. It's hard to keep the paper attached to the curve/angle. It's just not that usefull as well.
Ken
Ken
Whew! Now I don't feel so badly when I admit I thought the flat ones worked so nicely, the one with the shapes would too. Mistake. Can't get the sandpaper to stay down inside the groove or in the curve.
My Feedback: (-1)
ORIGINAL: bingo field
I have used a cheap spray adhesive at Menards...claims to be epoxy..stuff REALLY works good..but I think its more for permanent sanding blocks..not sure it will come off without some serious work...
Works good for making a bunch of sanding blocks from scrap though..
