 what to glue canopy on with? >
Old 11-11-2010 | 10:28 PM
Default RE: what to glue canopy on with?
ORIGINAL: Jim_Purcha
I would like to know how to use canopy glue. I guess my first canopy didn't have a proper fit. I have some Formula 560 but it seemed too runny to apply properly which I wasn't expecting. Anyone had good experience with this glue?
Any good techniques to attaching a canopy to model with glue?
Jim
ORIGINAL: from post #17 above:
I've used both brands and found that when you apply it, it beads just as described. If you go over it then with a Q-tip, the cotton ball spreads it and gives a more uniform distribution. It is surprising to see it spread out and stay, after beading like it did, but it does. It appears to get some tooth from being "brushed" over the covering. In fact, it acts tackier then when the canopy is positioned.
Do the same to the canopy before positioning it. Run a thin bead around it, then come along with another Q-tip and spread it. There seems to be a timing deal going on. Or it might be breaking through release agent. Although I always wash and dry the inside of any canopy before it goes on.
Good thing with the stuff is how easy the excess that's squeezed out is to wipe away.
First time I tried the stuff, I was hoping it was easier to deal with than epoxy. Turns out it's night and day easier.
I usually place some strips of masking tape on the canopy before starting with the glue. They will be pulled down onto the fuselage when the glue is on and the canopy is placed.
Shake up the glue bottle and then spread a line around the fuselage where the canopy will make contact. Then spread a line around the inside of the canopy where it's going to touch the fuselage. Use the Q-tip as mentioned on both.
Place the canopy and pull the tape down to hold it firmly in place.
Some glue will squeeze out. Use a damp paper towel and wipe it away.
Next morning, pull the tape.
Old 11-11-2010 | 10:37 PM
ram3500-RCU's Avatar
My Feedback: (221)
Jim
I use it all the time. Fit the canopy so it is tight everywhere. Put a couple "locator" pieces of tape on the fuselage where the canopy should sit if need be. Now put a small bead of glue on the edge of the canopy all the way around. Don't hold it upside down. The glue will run inside. Hold it on it's side and rotate it as you glue it. Now quickly put it in place using the pieces of tape to align it quickly and accurately. Now use masking tape to hold the canopy in place. Run the tape over the top and down each side in the middle, then front and rear. Pieces can be added down the sides if need be. This glue dries clear. If it is still white, don't remove the tape. This is important. You can't rush this glue, but it is the best. It is also cleaned up with water. Very nice stuff.
Old 11-12-2010 | 12:17 PM
My Feedback: (22)
I haved everything mentioned in these posts.canopy white glue dries clear and goop works as does pacer goo .it all works but I prefer some type of screws .not sure what your objection is all about but screws are easily removed and you can cover them with striping tape as well.I rather like the look and its easy accessibility.but to each his own..
Old 11-12-2010 | 01:24 PM
Airplanes400's Avatar
My Feedback: (349)
Use Elmers White glue. It's the exact same stuff as Formula 560 Canopy Glue that is sold by Pacer.
Also, JZ RC-56 re-packages Elmers glue and markets it under their brand. It's all the same stuff ... Elmer's White glue.
I've used Elmers for many years, it holds extremely well, never failed, and provides a strong bond to paint, lexan, Monokote, and every other plastic coating. Plus, Elmers is the least expensive. Pacer and JZ are nearly 6x more expensive!!!
Old 11-12-2010 | 01:38 PM
My Feedback: (89)
Hi Folks,
When you "rough-up" the edges of the canopy and attempt to clean off the plastic "dust". sometimes it just sticks all over inside the canopy due to static electricity.
Try a "Used" sheet of BOUNCE Fabric Softener, wiping the INSIDE of the canopy and it will remove the dust and prevent the plastic from attracting more dust & dirt.
A "USED" BOUNCE Sheet also works well for cleaning and removing MonoKote adhesive from the face of your hot covering iron. Fold the Bounce sheet and rub the hot iron over the sheet.
Ken AMA 1528
Old 11-12-2010 | 05:30 PM
  #31
My Feedback: (221)
ORIGINAL: Ken Kehlet
Hi Folks,
When you ''rough-up'' the edges of the canopy and attempt to clean off the plastic ''dust''. sometimes it just sticks all over inside the canopy due to static electricity.
Try a ''Used'' sheet of BOUNCE Fabric Softener, wiping the INSIDE of the canopy and it will remove the dust and prevent the plastic from attracting more dust & dirt.
A ''USED'' BOUNCE Sheet also works well for cleaning and removing MonoKote adhesive from the face of your hot covering iron. Fold the Bounce sheet and rub the hot iron over the sheet.
Ken AMA 1528
Great tip Ken. Thanks for sharing it.
Old 11-12-2010 | 05:42 PM
  #32
My Feedback: (221)
ORIGINAL: Airplanes400
This is interesting. I'll have to look into this. Having used Elmers glue for years, I must have missed the correlation. Elmers does dry fairly clear, but gets more hard and brittle. I'm going to compare the stuff side by side after your post. It would save money if it worked just the same, even if it isn't quite the same formula.
Old 11-12-2010 | 05:43 PM
  #33
opjose's Avatar
I THOUGHT that Pacer's was silicon based, but I searched for and found a non-toxic materials certification sheet put out by Pacer for the Canopy Glue and you are absolutely RIGHT.
Pacer's is just Elmer's glue...
Sheez... new one on me.... and Pacer's is actually THINNER than Elmers...
I Guess this is just another of those "pull the wool over Hobbiest eyes..." type of things, as done with Blemderm tape, etc.
I'll have to go back to trying Elmer's again...
Old 11-12-2010 | 05:52 PM
  #34
opjose's Avatar
ORIGINAL: ram3500-RCU
It's the same formula, just different amounts of water per volume.
I found the materials sheet on a UK site where Pacer had submitted spec for certification.
It's exactly the same as Elmer's according to Pacer's own description.
Old 11-12-2010 | 05:57 PM
  #35
My Feedback: (221)
ORIGINAL: opjose
Wow. Just goes to show how much we can learn from each other. This is great. Thanks.
Old 11-12-2010 | 09:58 PM
  #36
ORIGINAL: richardgerardi
I have used Goop for Home Depot with good sucsess.
You may or may not get away with it.
it can go very badly if it cracks, checks or melts the canopy.
