Electrostik Motor
I purchase the electrostik and during the assembly I unplug the ESC from the brushless motor. The motor has 3 different colors but the ESC has all black wires. I connect the wires to see which direction the motor is turning. If it is reversed I need to unplug and switch any two motor wires. But the motor will not run at all. What possible can cause this to happen?
ORIGINAL: mrcoolpop
No problem, I am thinking of getting one myself. i just cannot decide if I should get the ARF or the Rx-R. It may just be easier to get the Rx-R so I don't have to find a motor that will fit the mounting holes.
Anyway good luck with yours.
