Scratch build... build?
IL
I know I am in way over my head, but id like to get a few things cut out for some ziroli p-47 plans I have. It's a project that I will chip away at over a few years, and I was wondering if there is a thread, or some good tips and tricks for transfering plans to the wood and the best way to cut parts out. Anything would be helpful. I appreciate it, and happy Turkey day to all! Thanks.
What I do in some cases, is have the plans copied and then cut the copied plans and put on the wood. I use rubber cement so I can take the paper off after I have cut the profile. Works for me.
There is no need to cut and destroy any drawings, you can transfer patterns via a soft pencil on see-through paper or just punch trough the drawing onto the wood in critical corners using a needle and then connect the dots.
My Feedback: (-1)
ORIGINAL: Mr Cox
