 What Fuel >
What Fuel
What Fuel
Old 01-06-2011 | 07:22 PM
Default What Fuel
I finally got my ALPHA 40 running tonight. However, im running it on 10% nitro RC car fuel. Is this a bad thing? Does it have to be for RC aiplanes? or is the "10%" universial?
Old 01-06-2011 | 07:34 PM
My Feedback: (13)
Default RE: What Fuel
The car fuel should be fine for your airplane engine. Does the label say how much oil it has in it? You want 18% oil. The nitromethane (10%) is fine.
Old 01-06-2011 | 07:43 PM
scooterinvegas's Avatar
I think car glow is low in oil compared to plane fuel. Maybe 10-12%. I would check the oil if I were you. 18% in your plane is good.
Old 01-06-2011 | 09:40 PM
jeffie8696's Avatar
If the fuel doesnt say what percentage of oil it has in it, Iwould stay away.
Old 01-06-2011 | 10:27 PM
proptop's Avatar
My Feedback: (8)
Traxxas car fuel seems to have more oil in it than most other brands...IIRC it's around 16%...which is marginal at best.
If you are using a different brand, you might want to either add some oil or buy some airplane fuel.
10% airplane fuel is generally cheaper than car fuel anyway.
Old 01-06-2011 | 10:35 PM
My Feedback: (-1)
ORIGINAL: jeffie8696
If the fuel doesnt say what percentage of oil it has in it, I would stay away.
Jeff, the fuel sold under the Hobby People label doesn't state on the can what it is but they advertised it as 18%, this is there 15% nitro fuel, I didn't look at the can of the other %s. The cans look like just Wildcat with a label change, WC is just 16% oil. I add 2% Klotz to it just to be safe. Whatever I'm doing my engines seem to like it but better safe then sorry.
Gene
Old 01-06-2011 | 11:44 PM
the car fuel is fine.
just make sure that your engine settings are on the rich side and the engine will be Aok
Old 01-07-2011 | 08:04 AM
ArcticCatRider's Avatar
The car fuel will typically have less oil in it. Just switch. Run 10% Omega airplane fuel in both.
I have run airplane fuel in cars for years with great results. If you're bashing around the yard, and not trying to set records...airplane fuel is fine.
Old 01-07-2011 | 10:23 AM
jeffie8696's Avatar
Ithink you could use any moderate nitro fuel with about 18% oil in both car and airplane engines if you dont want to buy more than one type of fuel. I hate to see airplane engines run on less than 18%lube unless its the fancy European high performance synthetics that we cant even get.
If you are worried try some SIGSynPlus airplane fuel. It is 100% synthetic but has enough lube to work good.
Old 01-07-2011 | 05:17 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Most fuels for cars have a lower oil content in them, you may want to bypass it and buy a new jug of fuel for airplanes. As most above have said, go with a fuel with at least 18% oil content. Most of the fuel manufacturers will list the percentages of thier mixes on their websites, so you can research before you buy.
Ken
Old 01-08-2011 | 11:14 AM
I better bin my model technics goglo and omega then since they have 15% and 17% oil respectively.I've diluted the modeltechnics to 12% and no issues just a fine running engine.But different strokes I guess...The car is the more severe environment.
