 Pushrod Connectors? >
Pushrod Connectors?
Pushrod Connectors?
Old 01-26-2011 | 08:34 PM
Default Pushrod Connectors?
Is there such a thing?
I can only find 12 in. sections of pushrods... :\
How do you get a pushrod to reach all the way to an elevator or rudder?
Old 01-26-2011 | 08:57 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Pushrod Connectors?
Pushrod's at Sig, several different lengths
http://sigmfg.com/cgi-bin/dpsmart.ex...1Manu_02SIG_01
Pushrods at Tower Hobbies, many different lengths from different manufacturers.
http://www3.towerhobbies.com/cgi-bin...EARCH=pushrods
Hope this helps
Ken
Old 01-26-2011 | 09:16 PM
Helps alot! Thanks for the info.
I appreciate it.
Chris
Old 01-27-2011 | 01:44 AM
Lnewqban's Avatar
Chris,
One of the reasons for which most of the available threaded metal pushrods are 12" is that if they are too long and are not supported along the fuselage, tend to bend when are pushing against the control surface (not when are pulling).
Note that some are plastic, wire or cable that slide inside a plastic sleeve, which should be properly supported along the fuselage.
There is also the pushrod built up with carbon fiber tubes or balsa wood stick and both metal ends.
Then, there is the pull-pull system, which are two cables or strings that connect each side of the servo's horn to two horns in the control surface.
Check these links out:
http://home.flash.net/~dynamic3/sig/007.htm
http://home.flash.net/~dynamic3/sig/008.htm
http://www.sullivanproducts.com/Prod...sMainFrame.htm
http://masportaviator.com/2008/10/26...ainer-part-ii/
