 New receiver question >
Old 02-06-2011 | 05:10 AM
YellowHawk's Avatar
Default New receiver question
I know I am running old technology but I have a quick question. I have the NexSTAR with the 4 channel rx that came with it. I would like to add the flaps on the wings so I need a new receiver. I have a Futaba Super 8 (8UAPS) radio. Its a 8 channel PCM/FM radio system. It has the module where I can set it to any of several frequencies in the 75mHz band. If I buy a new 8 channel receiver, would I be better getting a PCM receiver as opposed to the FM receiver I have now? If I do, will my standard servos that came with the NexSTAR work with PCM?
I bought the tx from a friend at work and it did not come with the receiver...that's why I don't have the 8 channel receiver that would normally come with the tx.
-Alvin
Old 02-06-2011 | 05:15 AM
My Feedback: (85)
Default RE: New receiver question
75mhz isn't that a ground radio?
Old 02-06-2011 | 05:23 AM
YellowHawk's Avatar
Uh...yes. That was supposed to be 72mHz!
Old 02-06-2011 | 05:43 AM
On a trainer it won't make much difference. The pcm is a little more up to date so why not get it.
Old 02-06-2011 | 09:22 AM
The 8U Super TX will operate both FM and PCM receivers. A servo will work with either receiver.
PCM rx design features improved reception over FM and a Failsafe feature.
I use PCM on larger, more powerful and Helicopter models with safety regards to others, and for piece of mind. (Actually a must on Heli's for Failsafe)
However I have, and still do, use FM with absolutely NO problems whatsoever! (Knock on Wood).
Pay vigil attention to Tx and Rx battery condition and your radio installation overall.
Remember to re-check balance/CG after your flap installation. Good Luck!
Old 02-06-2011 | 09:26 AM
YellowHawk's Avatar
Thanks. I was just thinking that since I need to buy a new receiver anyhow, maybe I would be better off with the PCM. Even if it's not necessarily that much better. Thanks for all the replies.
Old 02-06-2011 | 10:18 AM
Lnewqban's Avatar
Alvin,
I agree with the previous posters.
Here you can find more answers to your questions:
http://www.futaba-rc.com/faq/index.html
Used 72 MHz radio equipment can be found in our RCU Buy and Sell.
A FM 8 channel including crystal can be found for $30 there.
High or low band need to be considered, if you are switching crystals in most receivers (switching crystals in a transmitter is a no-no).
http://www.rcuniverse.com/market/category.cfm?catID=122
FM is good enough and PCM has higher resistance against interference.
With so many fliers using 2.7 GHz, interference for 72's users is almost null.
Now, for the Aerodynamics of your question:
Trainers have wings with enough lift capacity as for not needing flaps for landings and take-off's.
This article about RC flying with flaps is interesting:
http://www.modelairplanenews.com/Med...ager/flaps.pdf
