How to chose a spinner
The easiest fit all,safest,and to be honest best solution is [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXK242&P=0]CLICK[/link].. If you choose plastic or aluminum regular style spinners be sure the openings for the prop blades are larger then the blade. You do not want the propeller to have awkward pressure on it while it is spinning at 12,000 rpm.
