 Smoke system >
Smoke system
Smoke system
Old 03-03-2011 | 04:06 AM
gboulton's Avatar
My Feedback: (15)
Default RE: Smoke system
ORIGINAL: yamahamx716
ok so i bought the pump u were talking about and have it installed with all the necessary plumbing. i was doing an intial ops check with water (pouring into a cup and not the muffler of course) and the 10oz tank emptied in about 8 seconds lol. obviously ive got some metering to do.
Well, the first question is how much voltage were you running? I've found mine's happiest around 5-ish V or so...a 4-cell NiCd works nicely.
Though I haven't tested water in mine, it wouldn't shock me if you get a faster flow rate with the thinner liquid as well...hrmm..worth considering/checking.
i also put in a "gboulton high performance aftermarket" metering block and screw.
Ok, first of all, that right there is funny. *lol*
i was just wondering what kind of flow show i aim for as far as having enough fluid flow/not enough flow. im assuming that when i actually hook it up to the muffler with a nipple the flow will be restricted therefor emptying the tank a lot slower. my guess would be fast enough to have constant flow coming out the nipple but not too fast where its pouring out like a straw.
Eh...hard to describe, really...but yeah, it shouldn't look like a straw by any means. yes, you want a constant flow, but you probably want to be down about as low/slow as you can be while still having a constant flow.
And yes, the muffler nipple and muffler pressure will also restrict things a bit, ime.
i tried screwing in the metering screw on the wooden block but my jamnut came unglued and thats all i have holding the screw in place. looks like its back to the drawing board for the metering screw contraption. (or a lot stronger glue)
Don't use a jamnut.
Here's what i do:
Drill a 1/4" hole in the hardwood where you want the "1/4-20 high performance metering bolt" to go.
Thread in a METAL 1/4-20 bolt. Run it in and out a time or two.
Remove it, and soak the hole with its new threads in thin CA.
Now you should just be able to run a 1/4-20 NYLON wing bolt in there, and call it good. Remember, this isn't a bolt we'll be removing and reinstalling constantly, so threading it into the wood will work fine.
Don't forget to have that metering system on the INTAKE side of the pump. Start the pump, run the bolt down to where there's NO flow, and then back it out JUSt enough to get a steady flow of smoke fluid. That'll make a decent starting point, and you can tune from there.
<br type="_moz" />
Old 03-03-2011 | 06:20 AM
MinnFlyer's Avatar
Ditto
As for flow, it's doesn't take much, but the only way to know is to hook it up and try it.
And gb is also correct in saying that oil will flow more slowly than water
Old 03-03-2011 | 08:35 AM
ok i agree on everything yall have said in regards to the fluid flow and oil flowing slower and stuff. refresh my memory on NiCD batteries...its 1.2 volts per cell, right...i used a a 7.2 volt battery so looks like it was a 6 cell (too much juice?). i only use lipos in my cars and plane and dont know a whole lot about nicd/nimh batteries. cant i buy nicd battery packs at radio shack and what should i look for besides voltage. seems they may be cheaper from there.
i did install that high performance metering valve (u should patent that!) on the intake side as instructed in earlier posts. also thats a good idea on putting the CA inside the wooden threads. thatll make the threads hard and not tend to strip out. hopefully i didnt drill the hole too big for a 1/4-20 screw.
yall have been a big help and i appreciate it all. like i said this is my first nitro plane and my other plane is a RTF. im new to the whole building thing. theres a lot of little things i come across that im not sure about and i want to do it right. even things like the voltage for the pump and stuff like that. can yall post a couple pics on here to show me your setup....im tryin to get ideas on how to lay everything out. i dont have very much room so i gotta find a way to cram everything in somehow.
Old 03-03-2011 | 08:57 AM
gboulton's Avatar
My Feedback: (15)
OH yeah..7.2V is WAY more than that pump needs, and would do EXACTLY what you describe.
As for where to get em? Eh...just grab a 4cell JR sport pack from Horizon or your LHS or whatever...shouldn't even run $20. or, optionally, if you're of an electronic bent, a cheap voltage regulator from Radio Shack would work fine...you're not pulling a lot of amps, and if you DO cook a few testing, not like you'll lose the airplane.
Last but not least, down the road, IF you happen to run LiPos on a gasser's ignition (as I do), then you may be regulating THAt down for the ignition anyway..if so, you can just come off there and drive the pump as well (Which is how i do it in my big Yak)
Yeah, well, if you did, i hear that the main body od the HPMV is a pretty easy part to replace.
Happy to see someone else getting smoked up! Just keep at it, you'll find the right combo soon.
<br type="_moz" />
Old 03-03-2011 | 09:02 AM
CGRetired's Avatar
I found this on-line.. tubing clamp made out of reinforced nylon.
Depends on how high-tech you want to get... The utimate is Gordon's (gboulton) of course..
CGr.
