Goldberg Tiger 2 owners and anyoneelse >
Old 08-09-2003 | 02:14 AM
Default Goldberg Tiger 2 owners and anyoneelse
For the aileron Servos what should I use for the arm(is that what it is called? The part that moves the rod) Futaba ones are too short it seems.
Could anyone supply a link to Towerhobbies of what I should use?
Old 08-09-2003 | 02:21 PM
Fastfly,
The plastic thing with a screw in the center is a servo horn. Some are round and some are star shaped. The plastic part on the other end is the control horn.
If you put the pushrod on the outermost hole, the Futaba ones should work OK. If you need the control to move further, move the rod inward on the control horn.
Tom
Old 08-09-2003 | 02:42 PM
Naw the Futaba Ones barely make it out of the plane. Thinking about getting the long arm ones.
Old 08-09-2003 | 03:26 PM
causeitflies's Avatar
How about a picture of the set-up?
Old 08-09-2003 | 04:26 PM
MinnFlyer's Avatar
Fastfly, are you using the 4 or 6 arm star wheels? the 4 arm wheels should be long enough. Go to Hobby Warehouse in Bloomington. They have a box full of them on the counter (in packets with all the other servo goodies like gromits, screws and those little brass thingies) for like $1.50.
PS They are also the best LHS around!
Old 08-09-2003 | 05:12 PM
Minnflyer Thanks ill pick up a few bags.
I was using the 6 arm star. I was buying stuff from towerhobbies so I just bought a 2 long armed control throw.
Cause it flys I didnt even think of that
