High wind technique
#52
AE, GERMANY
ORIGINAL: Top_Gunn
How does a plane ''weathervane on its own''? (Short answer: it doesn't.)
#53
AE, GERMANY
ORIGINAL: k1201ltc
TruBlu02,
Both of your videos were awesome. I especially like the G5 one because tonight I am going to go practice.
This whole thread has taught me a lot. I want to thank everyone including the poster who started this ...
I noticed your throttle management on the video and I will make sure I practice that as well.
I just bought a 1/4 Balsa USA Army Piper Cub and I need to make sure I don't break it on the maiden flight
Not to hijack the thread, but THANKS for the information. Now, I have some work to practice on the simulator before I head to the field this weekend.
TruBlu02,
#54
The nose will naturally point itself into the wind unless you do something to correct it such as adding rudder and aileron for the flare. So yes a plane will weather vane on its own.
The usual illustration of this is somebody in a hot-air balloon flying an RC model around the balloon. The pilot of course feels no wind. People standing on the ground do. Does the plane? Of course not. Same even without the balloon.
Stick and Rudder, p. 340. "an airplane flying in a steady wind flies no differently from one in still air."
#55
My Feedback: (-1)
Unless I slow down and start flying my plane backwards. I have a lot of fun doing that. Or turning cross wind and lift the wing and watch my plane flip over. Or if I'm in a verticle climb into the wind and the plane is pushed down wind. I do let the plane have it's own way quite a bit in the wind, it's a lot of fun.
#56
If you are in a full scale airplane, above the clouds so you can't see the ground, there is absolutely no way you can tell which direction a steady wind is blowing in.
Here's a nice illustration based on one that somebody used in an earlier thread. Suppose you are on the deck of an aircraft carrier, going north at 30 mph on a day when the wind is from the south at 30 mph. On the deck, you (and your model) will feel no wind at all. So you take off and fly around. Will your plane behave the way it does on a calm day at the field? Or will it "flip over" when you turn toward the east or west? It is, after all, flying in a 30 mph wind, in some sense. But, just as you can't feel that wind, neither can your plane. And if you jump off the deck into the water, you will now feel a lot of wind (until you get sucked into the props, I suppose). Does this mean your plane will now "feel the wind." Of course not.
My beginning students say all the time that the wind is doing weird things to their planes. So I have them put in some aileron trim and up elevator trim and go hands off. The plane starts turning, and doesn't stop. It doesn't turn more into or away from the wind or flip over. It just makes the turn, though not, of course, in a circle. Try it on a simulator some time: there, you can dial up a perfectly steady wind.
#57
My instructor told me the same thing about the plane not feeling the wind. To me, there is no doubt that the wind (and not just gusts) have an effect on the plane, otherwise we would not have this discussion about how best to land on crosswinds. Tail winds make a flight faster and a head wind the opposite. From what I see, the idea of feel could be explained by a boat going at one speed but its speed over water is different than the speed over ground if there is a current. Is that what you mean by "feel" the wind?
</p>
#58
AE, GERMANY
ORIGINAL: Top_Gunn
Sigh. As many, many posts here have noted, a plane flying in a steady wind ''feels'' no wind, and therefore cannot be turned in any direction. Wind is a mass of moving air; a plane flying in that mass of air has no wind blowing ''at it'' from the side, and will not turn. Gusts, of course, are a different matter, so a plane flying in the wind may turn in any direction because of gusts.
Stick and Rudder, p. 340. ''an airplane flying in a steady wind flies no differently from one in still air.''
#59
Your on the right track. Wind is only an issue when you bring the ground into the mix. Ground track and speed are definitely affected but the air speed and control are not. Where people run into trouble is when they compensate for groundspeed, by changing airspeed, or ground track, by crossing the controls. On the ground where you have the wheels applying force then wind can cause the plane to weathervane or flip, but not in the air. Of course gusts and thermal activity are another matter.
#60
TruBlu02, I am sure you get it, but your choice of words can be misleading. The plane will not automatically weathervane due to wind. A better way to put it would be to say you compensate for the fact that the wind is carrying (not pushing as this implies a side load) your plane in a direction other than your heading, so you change your heading to compesate for this. This gives you the crab angle and can feel mostly automatic for an experienced pilot. For the newer pilots you need to understand that in this crab the "relative wind" or the "wind" that the airplane feels, is still directly off the nose if you are not applying rudder, yet you will still be crabbing.
#61
AE, GERMANY
ORIGINAL: cfircav8r
TruBlu02, I am sure you get it, but your choice of words can be misleading. The plane will not automatically weathervane due to wind. A better way to put it would be to say you compensate for the fact that the wind is carrying (not pushing as this implies a side load) your plane in a direction other than your heading, so you change your heading to compesate for this. This gives you the crab angle and can feel mostly automatic for an experienced pilot. For the newer pilots you need to understand that in this crab the ''relative wind'' or the ''wind'' that the airplane feels, is still directly off the nose if you are not applying rudder, yet you will still be crabbing.
#62
Tru, looking at the whole post and ignoring that one word it was obvious you had it right. It's just too easy for a slight slip in wording to turn the posts ugly. I also agree that it is more intuitive with full scale. That is why it is so important to get a solid understanding of how wind affects flight, because it does affect it. The problems arise when the effect is misinterpreted, and too many model "instructors" don't fully understand it.
#63
We have to react to what the plane is doing and from our perspective on the ground the plane is going to weathervane into the wind to maintain a proper ground track. That is the purpose of crabbing in the first place. That is the only point I am trying to make here.
To return to the OP's point (post 57), none of this says that the wind has "no effect" on a plane. A plane flying in a mass of moving air moves (relative to the ground) right along with that mass of air, so if you have a crosswind blowing straight at you when landing, the plane will be carried toward you, sideways, at the speed of the wind if you keep the nose pointed straight down the runway. The purpose of crabbing is to counteract this. But you, the pilot, have to make it crab.
#64
My goodness, a lot of you should not be teaching. At least Top Gunn knows what he is talking about. All those of you who are saying you hold on rudder in a crosswind or steer with it need to get some basic flying lessons, not be the teacher!
In flight, the "wind" will be on the nose of the plane, it is not from the side. If you want to fly along the runway or on any track over the ground, in a wind that is blowing across that track, you do not hold on rudder or try to weathervane into wind with the rudder. All you do is turn slightly into wind using the ailerons as normal in a turn. Then with all the controls at neutral the plane will fly along the desired track over the ground. The plane will feel the wind coming from its nose as usual. It is only you, standing on the ground and not moving with the wind, that thinks the plane is crabbing. Reduce power and descend, rudder and aileron still at neutral. Take that all the way down to the runway. Ideally use a touch of out of wind rudder just at touchdown to straighten the plane along the runway but for models it doesn't matter so much. That's how easy it is, none of this sideslip nonsense with dangerous and difficult crossed controls. Fly crosswind with ailerons and rudder at neutral. Turning is always done by banking the wing, and unless you have an old 3 channel model, always use ailerons to control bank. Aeroplane rudders are not like boat rudders, they are not used to steer, they are used to keep you straight.
#65
AE, GERMANY
ORIGINAL: HarryC
#66
ORIGINAL: TruBlu02
Well i think some of the confusion has come from the fact that we are addressing two different parts, the approach and landing.
ORIGINAL: speedracerntrixie
Use rudder in the opposite direction that the wind is blowing you. I was practicing my IMAC sequence on Friday with a cross wind and had to hold 1/2 rudder stick to fly a strait pass.
ORIGINAL: TruBlu02
let the plane weathervane into the wind ….. It will naturally do this
ORIGINAL: capo915
heading is controlled with rudder. You can always crab it in like a couple of guys have mentioned but it looks sloppy and you generally, unless you're very proficient, land on something other than the runway. Rudder allows the plane to remain relatively stable on approach
ORIGINAL: lopflyers
Ailerons are useless when you are close to the runnway, in fact they can damage your precious model
ORIGINAL: Flak
I teach using the rudder to turn the airplane,
ORIGINAL: clip100
Here is an easy tip to remember for rudder control on cross wind landings. During final approach and the plane is coming towards you push the Rudder stick where you feel the wind on your face.
ORIGINAL: TruBlu02
ORIGINAL: TruBlu02
It does not matter what the plane ''feels.'' ...........the plane is going to weathervane into the wind to maintain a proper ground track.
#67
Flying in a wind is exactly the same as flying in no wind - if the plane isn't travelling where you want it, make a conventional turn with aileron until it is travelling towards where you want it. It might not be pointing in the exactly the same direction as it is travelling but that's a ground based perception problem. So if the wind is across the runway and the plane is drifting off to one side of the runway, simply make a small conventional turn until the plane is travelling along the direction of the runway. Rudder simply doesn't come into it. No plane in flight will weathervane into wind, it is physically impossible. For a landing in a crosswind, full-size don't like the side loads on the tyres or the destabilising effect of front wheels on taildraggers, so just as it touches down add a bit of rudder away from the wind to yaw it to point along the runway. Don't do it too early or the plane drifts across the runway. For models it is less important. That's the only point in a crosswind landing that you need rudder.
H
H
#68
<font size="2">
Harrryc</p>
Following what you said, I use the sim and tried with 12 miles wind directly across the runway (no turbulence added intentionally). I noticed the plane acts eratically, dropping one wing or another and seems to do the crabbing by itself. I only use ailerons. I use 3 notches above the idle on the throttle. I am able to land but I noticed this way that the real challenge is the thottle. I have to add or reduce power and when I do a good job at the throttle, using only the ailerons I am able to do a decent landing. </p>
What I find incredible is that so many RC modelers who are probably very good at the craft can use different techniques and all succeed to land perfectly their own way. I have to say I am so thankful to all for their input. This place is such a great resource for beginners like me.
Harry</p></font>
Harrryc</p>
Harry</p></font>
#69
AE, GERMANY
ORIGINAL: HarryC
H
H
I'll admit there has been some misleading info in this thread including some of my own. I have always used the term weathervane and I see now it is probably not the best way to describe a crab. it makes sense in my head and is very intuitive to me. To a beginner I can see where it would be a confusing and misleading term. To the OP If I confused you in any way with my terms then i apologize for that. My sim video shows everything I have been trying to describe (not very well apprently
#70
Trublue,
Your sim video looks great but difficult to copy. At least for the moment.
Why do you think I have to use the throttle so much to avoid a bad landing, and most of you seem not to mention it at all?
Also, the upwind wing seems to be blown up all the time like gusts in the sim. I did not add turbulence, just 12 miles wind. What is the easiest way for a beginner to deal with this wing problem? I can correct it at 10 feet, but close to ground it's usually too late. NO need to mention to you that at this time, I am still using ailerons :-)
AE, GERMANY
Harry,
When you have a strong crosswind it is in effect a headwind. A headwind will slow your ground track and also make reduce your power off glide distance. To counteract that effect you have to use more power to compensate for the "headwind." This is no different than using more throttle to control your descent whne you have wind right down the runway.
As for the wing being blown over it is not a wind gust that is doing that. When you use the rudder to bring track the nose around it also causes a rolling action. This is especially bad with a high wing trainer. Take the airplane up in the sim and use the rudder only to make a turn. What you will see is the tail move firstthen the out side wing will rise. To stop the turn use opposite rudder and the inside wing will com back up. This is how you fly a 3 channel aircraft on rudder. Now that is not the proper way to do a turn but is good for demonstrating why the ing will rise when straightening out in a cross wind.
Once the wing starts to rise the crosswind can get underneath it and compound the propblem. if you watch closely in my sim video you can see me use some opposite aileron right before I touch down. The reason I do that is to keep the wing from rising and flipping the plane over. This also keeps the plane from drifiting off the runway.
#72
After reading most of these posts, HarryC in my opinion has it right.
I practice using rudder only in normal flight with my sport planes. Practicing rudder only is not the most fun in the world, it's like being forced to practice the piano as a kid. I mention using the rudder because I don't use it on crosswind landings.
I love flying in the wind and I love crosswind landings. 20 MPH is my max. 20 MPH is a hefty smack in the face. On approach (unless my fingers do it subconsciously) in a crosswind I use ailerons only. The airplane crabs in. I DO NOT use rudder. I am conscious of using rudder right at touchdown and rolling out.
I've experimented using rudder on approach and I nearly crash every time.
#73
It's kind of fun to use crossed controls in a strong wind. We used to call this a "Chinese pass," though that may have been a slur. And slipping to lose altitude can be a useful skill. I once had a Cub that I flew at a small field, and it needed to slip to get down unless there was a strong headwind. But, apart from that, I agree: you can make a very decent crosswind landing without using rudder, and it's a lot easier to do it that way.
#74
AE, GERMANY
ORIGINAL: WestCoastFlyer
To clarify I do not advocate using rudder to maintain a crab. Small corrinated turns with ailerons will help establish crab andgle and ground track on final. Once in the flare the rudder comes into play to align the nose with the runway along with some opposite aileron to keep the wing from rising. If the wind is light it will take very little aileron but it is something to be contious of when landing.
#75
TX
HarryC and Top Gunn, Those are YOUR opinions and it sounds like you guys are quoting directly from a full-scale book on approaches and landings. Much different with R/C. Im not saying your opinions are wrong, Im saying there are different ways to attack a cross-wind landing. And please read my posts thoroughly because when you say "ailerons are in reverse and rudder isnt, not in my book" then you are not reading the full post. I clearly state the rudder is also in reverse so read the whole post.
The reason the OP posted this is for MANY different opinions not just one. I fly totally different from others and vice versa. If we all did the same in flight there would be no reason for this website or its forums. Please dont be elitists and pretend there is only one way. It also depends on the aircraft you fly. There are different approaches and landings for different aircraft especially WARBIRDS!
Remember this is the BEGINNERS forum
