 Fuel Flow Direction, A or B? >
View Poll Results: A poll
A is Correct
21.74%
B is Correct
78.26%
Voters: 23. You may not vote on this poll
Old 03-28-2011 | 12:18 PM
MetallicaJunkie's Avatar
Default Fuel Flow Direction, A or B?
i got a new fuel filter in, and i just wanna make sure i "install" it correctly
Old 03-28-2011 | 01:11 PM
JollyPopper's Avatar
Default RE: Fuel Flow Direction, A or B?
Are you open to thinking out loud guesses or do you want an answer from someone who uses these filters and actually knows which way they go?
Old 03-28-2011 | 01:18 PM
carrellh's Avatar
Other than the size it looks like the filter elements we used in automotive carburetors in the 1970s. B was correct for them.
Old 03-28-2011 | 01:19 PM
No answer means guesses are fair game. Its a filter, not a check valve. That being said, most filters are installed so that the fluid going through them travels from the outside to the inside. More surface area on the filter element mean longer life before clogging can occur. My two cents.
Old 03-28-2011 | 01:38 PM
No hits because either side would work. Its a little too much to worry about. The flow from either side will be fine. These arent extremely complicated parts. We just make em that way.
Old 03-28-2011 | 03:17 PM
B- 8:1 thanks guys/ i sometimes tend to over think stuff
Old 03-28-2011 | 04:29 PM
tacx's Avatar
If there is a screen on one side of the filter it goes on the down stream side of the flow.
Old 03-29-2011 | 12:10 PM
Banned
There are other types of Glow filters out there that aren't complicated in any way, and do a fine job in keeping the dirt out. My filters like some of the Du-bro Glow Filters only have a screen, and it can go either way.
Pete
Old 04-01-2011 | 11:13 AM
Either way will work, just don't reverse it in a year without cleaning it or you will pump all of the trapped stuff directly to the carb. Install the same way on any additional planes you may build (develop a habit). Or just filter the fuel when it comes out of the transport bottle and forget it. (controversy alert)
Old 04-04-2011 | 09:46 AM
tacx's Avatar
Connect it so the fuel is flowing TO the carb.
SORRY, JUST HAD TO SAY IT.
